Pulse activator
foroxc
Posted: June 01, 2017 at 7:20 AM / IP Logged Link to Post Post Reply Quote foroxc
Hi I’m trying installs automatic folding mirror in my car but I ran into a little problem, I want the mirror fold in when I press the lock bottom once and fold out when I press the unlock bottom. But my car lock the door when I change the gear to Drive (D) and the mirror fold in when that happens. My question is there is one way to activate de mirror when I press the lock bottom twice?
Sorry for my grammar English is not my first language.
Thank in advance.
Carlos
tdbaker021
Copper - Posts: 98
Posted: June 01, 2017 at 9:26 PM / IP Logged Link to Post Post Reply Quote tdbaker021
This should work for ya
Pac TR-12
foroxc
Posted: June 02, 2017 at 7:24 AM / IP Logged Link to Post Post Reply Quote foroxc
Yes, Thank you so much tdbaker021 that's exactly what I need.
Thanks again.
KPierson
Platinum - Posts: 3,527
Posted: June 04, 2017 at 11:44 AM / IP Logged Link to Post Post Reply Quote KPierson
You really should implement a way for the circuit to NOT work when the ignition is on. If you integrate an ignition cutoff to the relays then they won't fire when the doors auto lock/unlock or when you or passengers hit the buttons manually when the car is running.
Depending on how the system was designed it's possible that you could burn out the motors each time the vehicle auto unlocks if the mirrors try to unfold when they are already unfolded.
Kevin Pierson
tdbaker021
Copper - Posts: 98
Posted: June 04, 2017 at 11:47 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Thanks again.
No problem this should work and do what you want it to do.
foroxc
Posted: June 16, 2017 at 6:35 AM / IP Logged Link to Post Post Reply Quote foroxc
tdbaker021 wrote:
Thanks again.
Just want to say thanks again and show my mod. see link attached.
click here
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
