Challenging Issues, 95 Lexus GS300
deaner_gs300
Member - Posts: 33
Posted: May 02, 2018 at 12:18 AM / IP Logged Link to Post Post Reply Quote deaner_gs300
Guys, I'm dying here trying to figure out what is going on with this car I'm driving. I picked it up recently because the motor is in great condition and has lots of good miles left. 1995 Lexus GS300. I come to this forum seeking help because after chasing electrical issues during my lunch break and on rare "smoke breaks" during my way too busy work schedule I thought about an old friend... Mike Elrod was an auto electronics specialist from Memphis and we were very close for a long time. During college and about 10 years after we played music together in various bands and were inseperable. What brought him to mind was tgat i kniw he could answer this problem. I know that you seasoned 12 volt specialists can help me because you've probably already seen this issue. I'm not only talking to you guys who were installing when these cars were new I'm challenging everyone here to help me fix this. Ask me whatever you need to find a conclusion. Here is my issue:
95 Lexus GS300 everything on one circuit in the kick panel fuse box seems to be inoperative, and then some. The circuit is the one containing all the accessory lights in the vehicle. That includes the map light, locking courtesy trunk switch, step lights, the vanity lights in the visors, the rear pillar interior lights, the switched dome light, trunk light, basically every accessory light in the car except the dash illumination. Also the door lock switch which is what made me think of installers and audio/alarm specialists. I remembered one day looking through the trunk and in the spare tire compartment was 2 things that had been removed from the car or one like it anyway. An ecm and a module with text on it that made me think it was an alarm module. I've found schematics on the car stereo system. Which just happens to also be inoperable. But i can't seem to figure out what it takes to get this all back in order. Another electrical issue is the tilt and telescopic electric steering wheel adjustment as well as both front seats forward abd backward adjustment. The other seat adjustmemts work just not the one to move the seats forward and back along the rails. I realize that not all of these issues are necessarily related to the main issues. I do think the bulk of them are connected to each other. Now I'm going to pose this question... If someone was to take out the module that runs the security system what would the resulting issues be? Please help me. This is an issue someone, possibly one of the forums' members has run into personally. To a smart member who is more electrically inclined than myself this is a good math problem.... To me it's the twilight zone i live in every day. From home to work from work to home. The car came with no key fob and ive never seen the security light illuminated. Im nit certain that tge security system was even from this car but it was likely that because it was definitely a toyota piece of the corrext time period. Im not even certain where the module fits when it's installed. I just asked this question because things just smelled funny when i saw that module and then when testing fuses the main fusebox under the hood has 0 volts at the accessory fuses. And when testing the map lights and switched door lights, they had a tiny amount of voltage when turned on or the door open with the switch in the "door" position. Like 0.4 volts when on and 0.0 volts when they were off. Please tell me what I'm dealing with. If you have questions I'll be happy to answer any that i can and if you need something tested i have a multimeter and I'll be glad to go out as fast as possible and check whatever might help you solve this. Thank you in advance for trying to help me. Between 50 to 60 hours of work and just now getting out of a wheelchair after an accident in November where i broke my hip and right wrist. Again thank you for even reading and/or trying to solve this issue.
Alpine CDE172BT - Infinity PR6500CS 6.5's - Zapco ST2X SQ - SSA Evil-6.5's Mid-bass - Zapco ST2X SQ - Sundown SD3 12" D4 - VFL Comp 2K... 1995 Lexus GS300 - The Frankenstein build & it changes weekly.
eguru
Copper - Posts: 340
Posted: May 02, 2018 at 7:34 AM / IP Logged Link to Post Post Reply Quote eguru
You might get better responses if you itemize (with numbers/bullets) the issues and what you have checked so far.
Way too long a paragraph to read without a break.
I certainly appreciate posts like yours that use proper grammar and spelling though.
geepherder
Platinum - Posts: 3,668
Posted: May 02, 2018 at 9:37 AM / IP Logged Link to Post Post Reply Quote geepherder
*Not a seasoned veteran- just a former installer/hobbyist*
Here's a link Ween posted a while back for looking up factory diagrams:
http://www.bbbind.com/free-tsb/
interior lighting has multiple fuses and an integration relay:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=84914
power seats could be a switch, wiring and/or motor issue:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=84921
tilt/telescopic steering:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=84922
You mentioned your accessory fuse was dead. Did you test it while the key was turned?
mgoetz74
Silver - Posts: 424
Posted: May 02, 2018 at 10:22 AM / IP Logged Link to Post Post Reply Quote mgoetz74
to me it really sounds like you have either a blown fuse under the hood or a bad wire going from the battery to the fuse box, maybe there was a rat or something that chewed through a wire. You need to start at the battery and check power (with a multimeter) on the wire coming from the battery. If that's good start with the ignition on and test EVERY fuse, you don't know how many time I hear " my radio doesn't work and I test the radio fuses" just to find another fuse blown and everything magically works. Or eve a loose fuse in the fuse box, had a cobalt a couple years ago that the fuse tested good when I put my meter on it but when I took it off it didn't make connection and the car wouldn't start. lost two days of installs trying to figure that one out just to come down to a fuse not making contact. This maybe one of those trouble shoots that hard to pin point with out the car in front of us
deaner_gs300
Member - Posts: 33
Posted: May 02, 2018 at 7:24 PM / IP Logged Link to Post Post Reply Quote deaner_gs300
Lol.. Thanks eguru for the compliment, i think, and you're so right i would have used a better format had i known it was going to be so long. Now that you point it out I'm almost embarrassed. I can take constructive criticism though. I figure we all should be able to considering we're gonna be criticized either way, right? Especially on the web.
So you think i should edit the post? I think I should edit the post. The whole time I was doing it I was copying it to my clipboard so i wouldn't have to do it again. I do appreciate it though. I'm just glad somebody looked at it.
deaner_gs300
Member - Posts: 33
Posted: May 02, 2018 at 7:33 PM / IP Logged Link to Post Post Reply Quote deaner_gs300
I understand and totally relate to what you're saying. I can say that i did check the fuses. And i actually started checking the voltage at the fuse box while the car was running so that too i know was a yes. Again I apologize for the long rambling post. I knew it was long but not until just now when i scrolled through it did I realize how long it really was.
deaner_gs300
Member - Posts: 33
Posted: May 02, 2018 at 7:43 PM / IP Logged Link to Post Post Reply Quote deaner_gs300
Do i know you? Challenging Issues, 95 Lexus GS300 -- posted image.
Thanks for reading my long arse post guys. I'm surprised I got so much attention. Now I'm going to see if I might get somewhere new or different. And the module I found looked just like the security module i guess but i think it's actually an ABS module. Lol
But the thing led me here and I realized that this is where somebody with some sense might see it. How ever did I not think about car audio and video installers and hobbyists? Must not have been thinking. P.s. New Hope sucks.
Thanks guys.
deaner_gs300
Member - Posts: 33
Posted: May 02, 2018 at 7:55 PM / IP Logged Link to Post Post Reply Quote deaner_gs300
Sorry senor goetz74... I thought when i replied to your message up above it would fall under yours. So the reply above was to you. And again thanks for even reading the thing. I'm at the end of my rope and the car is the last of it. I barely have time to even think about it, but before i leave whirl everyday i go onto the ALLDATA website and pour over more data on the car. Hoping something jumps out. Sadly I haven't had as much time diagnosing because i can't move and get as precariously perched under the dash as I'd like considering my recent accident and broken.... Stuff.. Thanks mgoetz74
deaner_gs300
Member - Posts: 33
Posted: May 02, 2018 at 8:18 PM / IP Logged Link to Post Post Reply Quote deaner_gs300
OHHH DIP!! I just realized that I posted this as FROM a seasoned installer.. It's SUPPOSED to say FOR A SEASONED INSTALLER! I'm certainly not a seasoned installer. I was once a salesman at AutoRadio in Memphis but not a seasoned installer. I did my own car audio but not for anyone else. PLEASE FORGIVE ME FOR THIS MISTAKE. I have a ton of respect for you guys, and girls (in case you didn't understand that my 'guys' is universal) I came here specifically to pose this problem to you as a group... And I've already gotten info i didn't have before. If anyone has anything to add please do. I apologize, I thought I could edit my post... Really sorry it's such a novel.
eguru
Copper - Posts: 340
Posted: May 02, 2018 at 9:43 PM / IP Logged Link to Post Post Reply Quote eguru
Have you checked any of your non-working items for a proper ground by measuring the resistance from the item's "ground side" terminal to battery negative?
