2006 Ford Mustang V6, Aftermarket Battery Recommendations
topless stang
Copper - Posts: 67
Posted: February 10, 2023 at 9:37 PM / IP Logged Link to Post Post Reply Quote topless stang
Greetings folks! For as long as I can remember I've always used Optima Red Tops as my starter battery. However within recent years I've had to replace them quite a bit. In this car in particular the red top was replaced twice under warranty & once again its failed, but now its up to me to replace. What are you guys using these days up front? I have a yellow top in the trunk with an isolator installed and that's been working wonderfully. This car is garaged quite a bit as I don't drive it during the rainy season, so I want something stout that has a decent shelf life and holds its charge well. I use a Nuco Genius 5 on the starter battery & a genius10 on the trunk battery, so while not in use the battery is maintained. Any suggestions? I usually run a group 34/78 or 25/75 so I can have two sets of terminals. The vehicle OEM battery is 590CCA, so anything rated close to that would be great.
