Need Diode Info, Where Are They Needed?
thekid65
Posted: May 01, 2024 at 2:56 PM / IP Logged Link to Post Post Reply Quote thekid65
New to diodes (i did read what is on the site). Can someone educate me on how diodes are typically used in auto wiring? I see on the site it references (1N4001, 1N4004, 1N4007) but i wouldn't know which guidelines or where to use them. For example I have power window switches that i am triggering relays via the ground wire. would a diode be used anywhere in this? just looking for ideas if anyone cares to share their go to uses for diodes
Platinum - Posts: 13,726
Posted: May 01, 2024 at 7:35 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Are the window switches generating a pop into your audio system when you raise or lower the windows? If not, no need for diodes. If it does make a pop through your audio system when you release the switches, a diode across the coils of the relay will eliminate this pop.
thekid65
Posted: May 02, 2024 at 9:14 PM / IP Logged Link to Post Post Reply Quote thekid65
still putting things together so havent checked that yet (speakers are not in place yet).Good to know though, will check when i can. Thanks for the info!
