Need Help Wiring up power mirrors
Jdmep3
Posted: August 03, 2003 at 10:39 PM / IP Logged
Hello
I have a 2002 civic si, i just purchased JDM civci type R power folding mirrors. now from the mirrors is 2 wires, 1 is white *power* and other is black * ground*.when black is grounded and white is triggered they fold in, BUT to get them to fold out the wires need to be swappedlike power to the ground and ground to the power
anyone could Possibly draw up a schemtic for me? and possibly run them to a momentary switch
Thanks in advance
-mike
thanks in advace
Ronald Mark
Copper - Posts: 66
Posted: August 04, 2003 at 10:19 AM / IP Logged
4 -wire
wire it like this, you will need 2 push button sw, or one center off.
djfearny2
Silver - Posts: 810
Posted: August 04, 2003 at 10:36 AM / IP Logged
you can do this with either a mom switch or two timer relays,. do you have an alarm after market if you do its even easier. email me and let me know i have to think about this
Jon
Installer/Help Technician
---coral springs florida---
greedy111
Member - Posts: 24
Posted: August 06, 2003 at 11:59 PM / IP Logged
the best way to do it is to buy the jdm honda relay that goes with the jdm mirrors.  or you could do it like this:
Need Help Wiring up power mirrors -- posted image.
your mirrors would be like the actuator.  if you have the jdm switch, it would be + to activate the mirror... other wise maybe you could use something like a window switch for open or close.
Ronald Mark
Copper - Posts: 66
Posted: August 07, 2003 at 11:07 AM / IP Logged
I see, you are resting them a ground. took me a few minutes to figure out what was going on. your way is simpler than a 4 wire. A 4 wire rests open.
