wiring in capacitor?
topfridgeman
Posted: August 08, 2003 at 12:24 PM / IP Logged
how do you wire it in correctly , parallel,or in line series with 12v in to amp???can't seem to find a wiring diagram online.
proper bo I tell thee!!
kidtransam
Copper - Posts: 99
Posted: August 08, 2003 at 3:38 PM / IP Logged
There is a Positive side and Negative side to the Cap...run the power wire from the battery to the POSITIVE side of the cap...and run the power wire from the POSITIVE side of the cap to the amp...then run the ground wire (same gauge as the power wire) to a good solid ground.
It will probably have to be charges first..some don`t have to be charged..but if it does, you will need the card, or resistor that goes with it.
With a torch and a big enough hammer...it WILL friggin fit!!
