Keyless Car
Fatboy_us
Member - Posts: 12
Posted: August 27, 2003 at 7:34 PM / IP Logged
is it possible to drive a car with remote start without needing to use the car keys
Curious if this is even possible
If It's Too LOUD Your Too OLD
drvnbysound
Silver - Posts: 289
Posted: August 28, 2003 at 8:10 AM / IP Logged
Yes it is possible, with a little bit of modification to your cars ignition. There is a lock which is part of the ignition which locks your steering column when the key is not inserted. You just have to find that particular part of your ignition and remove it. However this is not recommended as it will be very easy to steal your vehicle after this is done. I have seen it done though.
SnomanF150
Silver - Posts: 269
Posted: August 28, 2003 at 3:41 PM / IP Logged
once the brake is pressed on MOST systems, the remote starter will shutdown...
a screwdriver and a hammer can bypass the steering lock on most cars.. and there's a pontiac.. Gran Prix I think.. the wheel don't lock at all. so if you drive without hitting the brake, you're good..
George
David's Car Stereo
Baton Rouge, Louisiana
