0.5volt trying to power 12v device?
HlH 3
Posted: September 05, 2003 at 4:30 PM / IP Logged
Hi,
I have a .5 volt signal wire that needs to power a 12v car device.  I thought of course put a relay on it, but from what I have been able to see - a 0.5v signal wont trigger a relay
Is there a special relay or something I can buy from radioshack or somewhere local to get this to work, or any ideas?
THANKS
auex
Platinum - Posts: 5,041
Posted: September 05, 2003 at 5:15 PM / IP Logged
Just curious, what are you trying to accomplish, and what are you using that supplies the .5V?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
HlH 3
Posted: September 05, 2003 at 5:28 PM / IP Logged
I am using a summit racing RPM switch, which is needing to trigger/power a vacuum solenoid for an intake manifold at 5300rpm.
The activation LED comes on at 5300rpm showing that it is working properly - and voltage goes from 0 to 0.5v so I know it's working... hardly.  I checked the ground, blah blah
auex
Posted: September 05, 2003 at 5:47 PM / IP Logged
That doesn't sound like it is working. It should put out 12V, is it part#      SUM-830449 ? I also noticed it said some bs about a protection circuitry and internal fuse. Have you tried to meter the output when the when it is disconnected?
BulletTooth
Copper - Posts: 122
Posted: September 05, 2003 at 7:40 PM / IP Logged
You might wanna try a simple transistor circuit, the only problem is that you will need about 0.65V to activate a transistor, however it might work with a 0.5V, you'll have to try. Let us know if you need any further help.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
