1990 Mercury Topaz
clamont
Posted: July 11, 2002 at 10:53 AM / IP Logged
Here is the Problem:  My girlfriends factory radio did not work, so I went out and got a Sony Fm/Am Cassette Stereo XR-1750.  I installed it myself and before talking with my brother cut the factory wiring harness out and threw it away.  I got one from the junk yard and rehooked it to the factory wiring.  I have a Metra Wire Harness for the Ford/Mercury which is fine.  I have everything hooked up, but now the Problem.  I have pulled different wiring diagrams from different web sites and my problem is this:
Unless I hook the illumination wire from the Metra Harness upto the 12 Volt Batt/Memory on the Metra/Sony Wires, than I have no power to the unit.  The next problem is that I still have no memory at the unit.  I can put all the Radio Channels in, and when I go away for awhile and come back, nothing is in the Memory.
The other problem is according to many wiring diagrams, there should not be a illumination wire for the Mercury Topaz, there is a dimmer, which I don't have hooked up, because when I do my lights are on all the time.
TopazBuster
bberman1
Gold - Posts: 2,314
Posted: July 11, 2002 at 11:41 AM / IP Logged
Double check to see if you have the wiring hooked up correctly and get back to us https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1988-90&make=Mercury&model=Topaz&ID=18421&type=Stereo
clamont
Posted: July 12, 2002 at 8:39 PM / IP Logged
Looks like all is hooked up correctly, put still same problem.
TopazBuster
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
