1998 Ford Mustang, Impluse 3100 Security
SteveO1778
Member - Posts: 12
Posted: July 11, 2002 at 8:07 PM / IP Logged
Hey guys, I got a new dilema. I thought that since I got the one working in my car that I would be helpful to my brother in law to install an alarm in his car. We got it all installed, and it seemed ok, but when I followed the steps for programming the remote, something went terribly wrong. Now the alarm just goes off constantly, and there's no stopping it. Also the parking lights that are supposed to flash just turn right on and stay on as soon as you plug the harness in, and that's when the siren starts going off. I have no idea what could have happened, but turning the key on and pressing the valet switch doesn't do anything to stop the alarm from going off. Anybody have any ideas?
Platinum - Posts: 12,488
Posted: July 11, 2002 at 8:31 PM / IP Logged
Make sure that the shock sensor is not plugged in when you plug the main harness in. Also, make sure that none of your trigger points are activated ( hood, doors, trunk, etc ). The Ford's have a (+) door trigger system , so I hope you used the PURPLE wire and not the GREEN.
SteveO1778
Member - Posts: 12
Posted: July 12, 2002 at 10:07 AM / IP Logged
I did use the purple. There is no shock sensor other than the internal stuff. It didn't come with an external shock sensor.
SteveO1778
Member - Posts: 12
Posted: July 12, 2002 at 10:12 AM / IP Logged
also, can you give me a diagram like the one you hooked me up with for my civic, showing what wires on the alarm go to what wires in the car and where they can be found? We may have used the wrong wires, but we checked them with a meter and they seemed right. THANKS!
Posted: July 13, 2002 at 7:19 AM / IP Logged
Ford
Mustang
1996-1998
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
WHITE/ PINK
IGNITION SWITCH HARNESS *
Ignition  #1:
TAN/WHITE
Ignition #2:
GRAY / YELLOW (14 AWG)
IGNITION SWITCH HARNESS **
Ignition  #3:
GRAY / YELLOW-2WIRES
IGNITION SWITCH HARNESS ***
Accessory:
BLACK/ L GREEN
Brake  Light:
RED / L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
ORANGE / WHITE
PIN #48 AT POWERTRAIN CONTROL MODULE*
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
D GREEN/ PURPLE (-)
BLACK 12 PIN CONN. DR. KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Powertrain Control Module Located In Passenger Kick Panel. ** 1997 + GT Models Are Equipped With Ford's PATS Anti-Theft System. . *** Ford Ignition 3 wire system. Relay required.
Ford
Mustang
1996-1998
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
YELLOW (5)
Starter  Kill:
WHITE/ PINK
Ignition  +12 Volts:
TAN/WHITE
Dome  Lights/Superv:
BLACK/ L BLUE (+)
GRAY 12 PIN PLUG IN DR. KICK PANEL****
OEM Horn:
PURPLE / ORANGE (-)
STEERING COLUMN HARNESS
Power  Lock:
PINK / YELLOW
12 PIN BLACK CONNECTOR *****
Power  Unlock:
PINK/LT GREEN
HIGH IN DRIVER OR PASS. KICK PANEL
Trunk  Release:
PURPLE / YELLOW (+)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
BLACK/ L BLUE (+)
Notes:
**** With OEM Keyless Entry Dome Light Wire Is GRAY (+) In 12 Pin Gray Connector In Driver Kick Panel. ****** Without OEM Keyless Entry  Reverse Polarity Door Lock Diagram, With OEM Keyless  Positive Pulse Door Lock Diagram.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
