radio problems
Regen
Posted: December 26, 2003 at 10:48 PM / IP Logged
Got a loaded Ford '03 F-250, put in Sirius H2A today & now the power windows don't work and the power to the stock ford radio doesnt work either checked all the radio and window fuses and they are all good
Thanks for any help!
lspker
Silver - Posts: 503
Posted: December 31, 2003 at 8:02 PM / IP Logged
Did you check the main fuse pannel under the hood?  Thats where the constant power fuses are, could also be a circuit breaker.  Did you disconnect any harnesses or pull hard on any wires?  The power could also shut off if door, light ect left on to long ( GM does this, Ford?) turn key and power might come back, but check every thing else first.
