relay to blow car horn on alarm
derrickg
Copper - Posts: 119
Posted: January 27, 2004 at 6:52 PM / IP Logged
i have a car alarm i want to add a relay to blow the horn when it goes off and i want to add air horns to that too please help
Bnluis
Silver - Posts: 578
Posted: January 27, 2004 at 6:58 PM / IP Logged
you can use this setup it will work it will only honk horn when alarm goes off, only. You will need a relay and a flasher. this is for light flash but wire it for you horn
relay to blow car horn on alarm -- posted image.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
derrickg
Copper - Posts: 119
Posted: January 27, 2004 at 10:00 PM / IP Logged
how much stuff can i hook up like this if i could can i put the alarm siren air horns and car horns on relays like this and pin 86 on the realy would have enough power to turn everything on
Bnluis
Silver - Posts: 578
Posted: January 27, 2004 at 10:02 PM / IP Logged
I wuold suggest using different relays and fuse them connect to battery, Good luck
Luis
Sound Waves
