T-taps
lakas187
Member - Posts: 28
Posted: March 01, 2004 at 10:29 PM / IP Logged
Where can i buy t-taps in bulk at wholesale prices?
Clean Install
Silver - Posts: 446
Posted: March 05, 2004 at 4:07 AM / IP Logged
www.partsexpress.com
If we learn from each success and
each failure, then we can improve ourselves
Basscoholic23
Copper - Posts: 67
Posted: March 08, 2004 at 12:28 AM / IP Logged
 cheaper here https://impulseusa.com/
customsound
Member - Posts: 29
Posted: March 09, 2004 at 1:21 PM / IP Logged
T- taps suck and are unprofessional in most cases. i would recommend not using them
Ravendarat
Platinum - Posts: 2,806
Posted: March 09, 2004 at 2:38 PM / IP Logged
I was gonna say the same thing when I read the initial post but I figured that if he wanted to use them he could find out on his own that t-taps suck
sroth140
Silver - Posts: 513
Posted: March 13, 2004 at 12:12 AM / IP Logged
t-taps suck... uhhh no way T-taps -- posted image.
solder n tape.
MECP certified installer
KaMLuNg
Copper - Posts: 70
Posted: March 31, 2004 at 1:10 PM / IP Logged
lolz hate t-taps w/ a passion also...
Teamrf
Gold - Posts: 1,031
Posted: March 31, 2004 at 2:52 PM / IP Logged
Whoever invented T-Taps should be smacked that is just a cheap "hack" way of doing things.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Sweekster
Silver - Posts: 481
Posted: March 31, 2004 at 6:16 PM / IP Logged
In the long run, it's cheaper to buy a soldering iron/gun, solder, tape, and a good, long extention cord. T Taps do save some time but you're gonna run into loose connection problems later on. But try Parts Express.
Duane...
If you think you're confused, imagine how you feel.   T-taps -- posted image.
Teamrf
Gold - Posts: 1,031
Posted: March 31, 2004 at 6:23 PM / IP Logged
T-Taps are for hacks....period.
~The Rookie~
