camaro 2001
paquito71
Posted: August 15, 2002 at 12:28 AM / IP Logged
      pleace i cuoul not find the stock amplif of mr camaro 2001  if some knows pleace let me Know
doobaby
Posted: August 17, 2002 at 6:37 AM / IP Logged
The most common place for the stock amp,especially Monsson Equipped, is behind the spare tire on the passenger side. If it is a Bose System the amps are usually located in the pods the speakers are mounted in. The Bose equipped Systems are a litte more complicated to deal with. The system is proprietary and it is best to rip the the whole system out and start with new head & speakers. The Monsoon amplifier is typically a 4 to 6 channel with built in cross-over for mids & tweets. If you are replacing this amp be sure to add at least passive cross-overs to the speakers eg: caps & coils. Good Luck with your system!!
Doobaby @ RadioActive
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
