lexus IS 300/2001/ airbag reset?
mecpcert_1
Copper - Posts: 83
Posted: July 18, 2004 at 3:07 PM / IP Logged
just installed pioneer's avh-7500 dvd into a 2001 lexus IS300. i put the hideaway tuner under the front passenger seat. in order to this, i first disconnected the negative battery terminal, THEN i unplugged the airbag for the seat. made all necessary connections for the pioneer tuner, (NEVER did i turn the key forward, either), plugged in the airbag conncetor to the seat. put negative terminal back on the battery.  powered up and all was good to go .........................with the exception of the airbag flashing. the airbag had a constant, steady single flash. ( just like my cursor!lexus IS 300/2001/ airbag reset? -- posted image.) other than taking the car to the dealership to have it reset, is there any other way to reset it ? i've heard of some cars resetting with just the turn of the ignition switch, pressing the brake/gas pedals in sequential order...................thanks in advance for any thoughts or ideas. (oh yeah, i don't have a scanner ,either.) this place doesn't pay enough for me to make that kind of purchase.
do it right the first time....less warranty work=more money!:)
slicksam
Copper - Posts: 291
Posted: July 18, 2004 at 8:07 PM / IP Logged
It has happened to me a couple of times, some cars you can disconnect the battery for 10 minutes, and it cleared the code.
But I had a 2003 maxima.....I Installed a remote starter on it....and I also realized that the air bag was flashing, I think It was my testlight that activated it. But my customer went to the dealer, they charged him like 10 dollars, they plugged the computer to his car and cleared the code.
But when you do go to the dealer....You make sure you explain what you did to activate it....cause they will automatically think you blew some computer on your car and try to hit you with a crazy bill.
Take care
Slicksam
mecpcert_1
Copper - Posts: 83
Posted: July 29, 2004 at 11:02 PM / IP Logged
thanks for the reply, slicksam. does anyone else have any other solutions?
any insight would be greatly appreciated, thanks.
hectormanuel
Posted: July 30, 2004 at 1:05 AM / IP Logged
you try disconect both baterry terminals  + & -  for 10 to 30 minutes?? my car give me the same error and i disconect the battery for 30 minutes and the air bag light stay off.
when you disconect the battery of the car for long time the computer internal battery discharge and when power up  the computer do a restart
hectormanuel
Posted: July 30, 2004 at 1:10 AM / IP Logged
another question your car no have a little botton on the speedometer?? if yes thats is a reset  button ,see the manual of the car to know
