How do I reduce 12V to 1V?
jman1113
Member - Posts: 6
Posted: September 23, 2004 at 9:07 AM / IP Logged
  How do I reduce 12V to 1V?   I am using a 1volt led and don't want to blow it as its a stock bulb.I could get a 12V led but it would'nt be stock.Thanks in advance,Joe
hi
Teken
Gold - Posts: 1,492
Posted: September 26, 2004 at 8:46 PM / IP Logged
470 - 550 ohm 1/4 watt resistor. Idealy you would have provided a current value for the LED, to be more accurate. But this range will do fine for a general purpose voltage drop.
Regards
EVIL Teken . . .
jman1113
Member - Posts: 6
Posted: September 27, 2004 at 8:40 AM / IP Logged
Thanks for getting back w/me.So I add the 1/4 watt resistor inline on the + side and that will do it . I am retro fitting my 00 vette with passenger side airbag cutoff switch and wanted the stock indicator light and bezel. this will complete it.Thanx again.J
hi
Mongol
Posted: October 06, 2004 at 10:32 AM / IP Logged
The LED really doesn't care if you give it 1 volt or 12 volts the thing that will hurt it is the current putting a resistor in line with the LED is what you want to do. Since this will be a series circuit the LED doesn't care if you put the resistor in on the + side or the - side just as long as you've got a resistor somewhere between about 200K ohm and 200 ohm. I'd tell you to use a resistor at or around 1k ohm. Remember the LED only works one direction, you won't hurt it if you hook it up backwards, but it only works one direction.
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
