UK Car diagrams/Technical details
coupecoupe
Posted: October 06, 2004 at 4:00 PM / IP Logged
Hi,
I'm new here (just joined today), been looking through the site for a while now and alot of the links on the left are very handy.
I'm about to install a Toad Ai606 car alarm to a 1994 UK Rover 220 coupe turbo, what i'd like is a wiring harness layout diagram or similar.
Is there a uk equivalent of this site, or can anyone on here help with the wiring details?
(i can manage without, but i'm sure you'll all agree that i'd make things 10 times quicker/easier!)
Ian
Liverpool - UK
Teken
Gold - Posts: 1,492
Posted: October 06, 2004 at 4:26 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - ROVER / 220 (UK) / 1995 / Remote Start
12volts
Starter BLACK/ white      4 pin plug, front of fusebox
Second Starter
Ignition BROWN / pink      4 pin plug, front of fusebox
Notes: Fuel pump cut wire is WHITE/ violet in o/side floor loom.
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock pink   5wi behind radio, wht plug
Notes: Programme out autolock.
Power Unlock orange   5wi behind radio, wht plug
Lock Motor
Unlock Motor
Parking Lights+ grn/wht & grn/red     16 pin plug,front of fusebox
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger vio/red or vio/wht    -   plug top left of fusebox
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Not Available
Regards
EVIL Teken . . .
