home sub?
bassrider20hz
Member - Posts: 40
Posted: April 07, 2005 at 7:36 PM / IP Logged
hello i just built a subwoofer box for my car but i took it out because its in the shop. the box is in my room. the subwoofer doesnt sound as it soundson the car. i cant hear the lows very good, only when i stand in the corner of the room i can hear the lows (so sweet) what can i do to be able to hear the sub all over the room    should i face the sub in a certain way????  please help.
geepherder
Platinum - Posts: 3,668
Posted: April 07, 2005 at 8:29 PM / IP Logged
See if you can set the sub in a corner.
ss-installer
Silver - Posts: 444
Posted: April 07, 2005 at 10:15 PM / IP Logged
i wouldnt suggest hooking it up to your home stereo.
bassrider20hz
Member - Posts: 40
Posted: April 07, 2005 at 11:13 PM / IP Logged
why not??home sub? -- posted image. i think it sounds very good and my house amp is 4ohm rated just likethesub. the only problem is that i cant hear the lows through the whole room only in the corners.   ive heard that if would work if i face thesub towardsthe floor  is this true.
thanks for your responces
geepherder
Posted: April 08, 2005 at 7:24 AM / IP Logged
It can help sometimes, or you can try turning it 90 degrees from where it sits, or reversing polarity.
Francious70
Silver - Posts: 629
Posted: April 08, 2005 at 9:18 AM / IP Logged
DYohn
Platinum - Posts: 10,741
Posted: April 08, 2005 at 12:02 PM / IP Logged
In a car you have a nice helping factor called cabin gain that will emphasize the bass from even the cheapest subwoofer at around 50Hz.  Placement is less of an issue since the physical space available is so small.  In a room you do not have it quite so easy.  Corner placement, etc. can generate some room gain, but it is all about the size of the room and what else is sitting in it. and how the sub is positioned, not to mention how the enclosure is constructed to optimize the woofer's performance, how the amp is EQ'd, etc.  The reason good home subs cost so much more than car subs is not simply because of nice veneered cabinets!
The articles linked above are excellent resources, by the way.
