2002 Dodge Ram Wiring
kozzy45
Posted: May 01, 2002 at 6:38 AM / IP Logged
Dose anyone know the factory wiring scheme for the New Body Style Dodge Ram 1500 Pickups?
Kozzy
the12volt
Administrator - Posts: 3,957
Posted: May 01, 2002 at 11:55 AM / IP Logged
Hi kozzy45, here's what I have for a 2002 Ram regular cab:
Radio Info:
Battery (+): RED
Accessory (+): RED / WHT
Ground (-): -Illumination:
Dimmer: ORG/WHT
Power Antenna: YEL
Factory Amp Loc: BEHIND GLOVEBOX
MAY HAVE INFINITY SYSTEM >
Front Speakers
Kit: FACTORY GRILL
Speaker Size: 6 X 9"
Left (+): DK.GRN
Left (-): BRN/RED
Right (+): VIO
Right (-):
REAR SPEAKERS
Kit: FACTORY GRILL
Speaker Size: 5 1/4"
Left (+): BRN/YEL
Left (-): BRN/LT.BLU
Right (+): DK.BLU/WHT
Right (-): DK.BLU/ORG
Alarm/Remote Start Info:
Battery (+): RED + IGNITION SWITCH HARNESS
Starter 1: YEL + IGNITION SWITCH HARNESS
Ignition 1A(+): DRK. BLU IGNITION SWITCH HARNESS
Ignition 2A(+): RED + IGNITION SWITCH HARNESS
Ignition 2B(+): RED / WHT + IGNITION SWITCH HARNESS
Accessory (+): BLK/WHT + IGNITION SWITCH HARNESS
Tach Sensor: RED / BLK OR BLK/GRY AT COIL ON DRV.SIDE OF ENGINE
Key Sensor: BLU (-) IGNITION SWITCH HARNESS
Neutral Safety: BLK/WHT (-) IGNITION SWITCH HARNESS
Brake: WHT/TAN + AT BRAKE SWITCH
Reverse Lights: VIO/BLK (+) 16 PIN GRY CONN DRIVERS DASH
Window Roll-Up:
LF:LT.BLU
RF:BRN/WHT
Window Roll-Down:
LF:WHT
RF:VIO/WHT
Door Trigger: BRN DRIVERS B PILLAR
Parking Lights: VIO/YEL - RELAY ISOLATE GROUND W/320 OHM RESISTOR
Headlights: PURPLE / YELLOW 680 OHM RESISTOR,SAME AS PARK LIGHTS
Pwr Door Lock: WHITE/ GREEN - DR. KICK USE 680 OR 815 OHM RESISTOR
Pwr Door Unlock: WHITE/ GREEN - DR. KICK PANEL USE 320 OHM RESISTOR
Horn: BLK/RED (-) 74 PIN CONN BEHIND DR. DASH OR COLUMN
Factory Disarm: LT.GRN/ORG(-) DR. KICK GROUND PULSE THROUGH 1500 OHM
DR. Mtr Unlck: PNK/BLK + LEFT KICK PANEL
DR. Motor lock: ORG/BLK + LEFT KICK PANEL
Factory Alarm: LT.GRN/ORG(-) DR. KICK GROUND PULSE THROUGH 760 OHM
Passenger Unlck: PNK/VIO + LEFT KICK PANEL
DOOR TRIGGER ALSO AT TIMER MOD
USE TAN FOR DR. DOOR AND BLK/LT.BLU FOR PASS DOOR DIODE ISOLATE
FACT ARM/DISARM WIRE WILL LOCK DOOR / 2 PULSE FOR UNLOCK
the12volt
