Tach Wire Location
Styles
Posted: December 06, 2002 at 3:54 PM / IP Logged
Just wondering if anyone know's where to find the tach wire inside the drivers side kick panel on 1997 Honda Accord. There is so many different sugguestions on the actual color and location.
securinu
Silver - Posts: 772
Posted: December 06, 2002 at 3:59 PM / IP Logged
plug above the fuse door it is a horizontal plug has like 20 wires and is blue as well
Styles
Posted: December 06, 2002 at 5:35 PM / IP Logged
I found that gray connector with the blue electrical tape, but I couldn't get a reading from it. Also there are two blue wires, one light and one dark blue wire with a red\tan color strip (I think or it has dotted lines). The gray connector only has 16 wires in it...Is this the right connector? It's the only one that doesn't have something plugged into it.
Moderator - Posts: 12,488
Posted: December 07, 2002 at 12:19 AM / IP Logged
Go to the distributor and there you will see a plug with about 6 wires ( maybe 8 ) and you will find a BLUE wire there. tap into this one.
Monday, December 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
