2 Radiator fans from one dual speed fan
l33t_a2
Posted: January 25, 2006 at 1:21 AM / IP Logged
My car came with a single radiator fan which has two speeds.
It is broken and I am going to replace it with two separate single speed fans.
I want to wire the new ones up so that when the low speed should be on, I have one fan going. When the high speed should be on, I have both going.
I have 3 wires going to the stock fan motor.
Ground, 12v+ for low speed, 12v+ for high speed.
First fan: Ground, 12v from low speed, also 12v from high speed on the same wire.
Second fan: Ground, 12v from high speed. No backflow current from low speed fan.
Is this possible?
The fans are rated at 8 Amps, I could only find a diode rated for 6 amps. I dont even know for sure how diode ratings work. I know how to wire up a basic automotive relay, but thats about the extent of my experience.
The car is a 1990 VW Jetta GLI 16v. It is a daily driver as well as a weekend track car.
Ween
Platinum - Posts: 1,368
Posted: January 25, 2006 at 1:39 PM / IP Logged
hi,
this should work.   bosch type SPDT relay.  terminals as follows.
87A to low speed fan wire of vehicle
30 to low/high speed fan (fan 1)
87 & 86 to high speed fan wire and high speed fan (fan 2)
85 to ground and both fans ground leads
hope this helps
mark
l33t_a2
Posted: January 25, 2006 at 9:31 PM / IP Logged
So youre saying this will work? thats what i got from reading your reply, thanks for the quick response.
2 Radiator fans from one dual speed fan -- posted image.
Ween
Posted: January 25, 2006 at 9:37 PM / IP Logged
the diagram drawn is correct except you need a jumper between terminals 87 and 86.
mark
l33t_a2
Posted: January 25, 2006 at 9:40 PM / IP Logged
ok, and also, if by chance im overthinking this and the low stays positive even when the high goes hot, will that affect the relay setup ?
l33t_a2
Posted: January 25, 2006 at 9:45 PM / IP Logged
geepherder
Platinum - Posts: 3,668
Posted: January 26, 2006 at 2:43 PM / IP Logged
No, it won't hurt anything.  That's what you want to happen.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
