1997 GMC C/K 1500 Pick-up remote starter
kefrizz
Posted: December 26, 2002 at 10:03 AM / IP Logged
I'm installing a security/remote start/doorlocks system in a 1997 GMC 1/2 ton pickup.  I have everything working except the Blower motor.  I've got it hooked straight up to the Orange wire as instructed in the manual, but the blower just won't blow.  I've tried hooking up to other wires but it seems to throw SES codes in the computer.  Any ideas?
Thanks in advance!
Platinum - Posts: 12,488
Posted: December 26, 2002 at 4:29 PM / IP Logged
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white *5            |+  |ignition harness            |
|   THIRD IGNITION|pink/white *1       |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness
*1 The pink/white does not exist on all models. *5 Make sure to enable second ignition wires for remote starts to prevent possible transmission damage and the check engine light from coming on.
All of the above connections ( if applicable ) have to be powered up in order for the blower motor to engage after remote start. Must use relays for this.
