2002 Mustang security
CustomAutoRes.
Posted: January 03, 2003 at 8:33 AM / IP Logged
We have been working with the door and trunk triggers for a couple of days now and have not found and answer yet.  What have you found out?
What we know so far is that the 12v power is turned off by the car after a half hour.  And we have found multible trigger wires but still testing them.
Custom Auto Resources .com
970-243-6620
Why just drive it? Customize it.
themagicone
Silver - Posts: 325
Posted: January 03, 2003 at 8:55 AM / IP Logged
there is a GEM in it. it will wake up if it see a zone open.
|              12V|yellow & lt. grn/pur|+  |ignition harness            |
|          STARTER|WHITE/ pink          |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|  SECOND IGNITION|gray / YELLOW         |+  |ignition harness            |
|        ACCESSORY|BLACK/ lt. green     |+  |ignition harness            |
| SECOND ACCESSORY|RED / black           |+  |ignition harness            |
|       POWER LOCK|lt. green           |+  |low in drivers kick or *1   |
|     POWER UNLOCK|purple              |+  |low in drivers kick or *1   |
|       LOCK MOTOR|RED / white           |   |low in drivers kick or *1   |
|     UNLOCK MOTOR|RED / orange          |   |low in drivers kick or *1   |
|    DISARM DEFEAT|pink/orange         |   |GEM module *1               |
| PARKING LIGHTS +|brown               |   |light switch or drivers kick|
| PARKING LIGHTS -|WHITE/ black         |   |*1                          |
|       HEADLIGHTS|RED / yellow          |+  |light switch                |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|BLACK/ white         |+  |drivers kick panel or *1    |
|  TRUNK/HATCH PIN|BROWN / white         |-  |drivers kick panel or *1    |
|TRNK/HTCH RELEASE|purple / YELLOW       |+  |drivers kick panel          |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|dk. GREEN/ purple    |-  |drivers kick panel or *1    |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|*3                  |   |*3                          |
|      SPEED SENSE|WHITE/ orange        |   |PCM pin 68 *4               |
|       BRAKE WIRE|RED / lt. green       |+  |brake switch                |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column or *1       |
|           WIPERS|white & dk. blu/orn |+  |wiper motor                 |
|  LF WINDOW UP/DN|wht/blk - wht/blk   |A  |drivers window motor        |
|  RF WINDOW UP/DN|tan/blu - wht/yel   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|yel/blu - gry/orn   |A  |drivers kick panel          |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |drivers kick panel          |
|        RADIO 12V|lt. GREEN/ violet    |   |at the radio                |
|     RADIO GROUND|black               |   |at the radio                |
|     RADIO SWITCH|BLACK/ pink          |   |at the radio                |
| RADIO ILLUMINATE|lt. blue/red        |+  |at the radio                |
|    POWER ANTENNA|ORANGE / lt. blue     |+  |at the radio                |
|       LF SPEAKER|orn/grn - blu/wht   |   |at speaker or amplifier *5  |
|       RF SPEAKER|wht/grn - grn/orn   |   |at speaker or amplifier *5  |
|       LR SPEAKER|gry/blu - tan/yel   |   |at speaker or amplifier *5  |
|       RR SPEAKER|orn/red - brn/pnk   |   |at speaker or amplifier *5  |
Notes:
NOTE: This vehicle has the PATS anti-theft system. Use DEI part number 555F to bypass during remote start operation.  *1 Also found at the GEM module located above the drivers kick panel to the drivers side of the steering column.  *2 There are two door trigger wires. Use yellow/black for the drivers door and gray/red for the passengers door. Both wires are found above the drivers kick panel in a 20 pin connector. Use both wires and diode isoate each. See direct fax document #1076 for wiring information.  *3 For the 3.8L motor, use the dk. blue/lt. green, RED / lt. blue, or the pink/white. All of these wires are found at the coil pack. The 4.6L motor uses a separate coil for each cylinder. Go to any coil and use the wire that is NOT red or WHITE/ lt. blue.   *4 The PCM is located behind the passenger kick panel.   *5 The amplifier is located just below the radio.
securinu
Silver - Posts: 772
Posted: January 03, 2003 at 10:59 AM / IP Logged
BLACK/ white at keyless module above driver kick area. ( + )
CustomAutoRes.
Posted: January 08, 2003 at 7:49 AM / IP Logged
Securinu
BLACK/ white does test as door trig. for both doors. but Yellow/black(-) and grey/red (-) isolated seems to work better.  And we ended up using our own pin for trunk.
970-243-6620
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
