Hot Glue On Circuitry
Jasonb61
Copper - Posts: 81
Posted: April 11, 2006 at 7:50 PM / IP Logged
Hello,
I recently purchased some M3 mirrors and like most products I get off eBay I took it apart to see how the quality looked on the inside...
Well, Luckily I found that the circuitry for the LED's was exposed! These are outside mirrors that WILL come in contact with moisture...
Anyways, I wanted to attempt and save them so I covered the circuitry (a few resistors and 2 diodes) with hot glue! The LEDs still work but im wondering if I made a mistake? The LED's wont operate for long periods of time so it wont generate a lot of heat... they will only come on with the blinker or alarm... Did I make a mistake??
-Jason
electrostatic
Copper - Posts: 154
Posted: April 11, 2006 at 8:07 PM / IP Logged
use red insulating varnish or silicone. hot melt glue is easy enough to remove.
Prove your connections, use a meter!
I promise, I'll behave!
firstrax
Copper - Posts: 113
Posted: April 11, 2006 at 8:18 PM / IP Logged
A lot of pc boards have a conformal coating to protect against moisture. A coated board looks almost identical to an uncoated board so your boards may have been coated. If not, conformal coatings are avaible from many electronics distributors in spray cans.
I doubt the hot glue will harm anything though.
Jasonb61
Copper - Posts: 81
Posted: April 11, 2006 at 8:22 PM / IP Logged
Ok *PHEW* I just needed some peace of mind... I also like the fact that hot glue will be easy to remove so I can fix a resistor or something if needed... :-D
stevdart
Platinum - Posts: 5,816
Posted: April 11, 2006 at 8:25 PM / IP Logged
It's just the heat of some resistors that could unmelt the glue, and that in itself wouldn't hurt anything but put a strain on the leads if the resistor is dangling, but otherwise it's fine to use.  I use it to build crossover circuit boards.  And I don't put in resistors that are going to get that hot!
