Four Speakers to a 2 Channel Amp
bjeremi
Posted: April 27, 2006 at 8:53 PM / IP Logged
I am installing four tower speaker on a wakeboard tower on a my boat. Its a seaseaswil tempo. Most of the componets I am using are hand me downs and I was trying to figure out the best way to hook them up. The amp I will be using is a Pioneer PRSX720
Specs:
100W X 2 / 4 ohms
400W X 1 / 4 ohms
Load Imp 1-8 ohms
Speakers are ks60
PMS 65 W
Peak Power 130W
Impeadence 4 ohms
I was trying to get advice on the best way to wire them up. I not the best with mobile audio and was wondering if it would be better to wire them in parallel or in series? If I should bridge the amp first or not. Any help would definitely be aprreciated. I realize this might not be the ideal amp but the wifey got me on a budget and there's not room to purchase another amp.
forbidden
Platinum - Posts: 5,354
Posted: April 29, 2006 at 11:45 AM / IP Logged
Wire them up as follows, one pair of speakers to each channel of the amp. Here is the ratings of your amplifier.
Continuous Power (20Hz-20kHz, 0.04% THD)
  • 2 ch: (4 Ohm) 100Wx2
  • 2 ch: (2 Ohm) 200Wx2  -  This is how you will be operating the amp.
  • 1 ch: (4 Ohm) 400Wx1
Four Speakers to a 2 Channel Amp -- posted image.
