current draw with digital meter
georgedal
Posted: October 07, 2006 at 12:42 PM / IP Logged
I have read to find the current draw in an automotive circuit you disconnect the battery negative cable and connect a digital meter set to amps in series between the battery and the disconnected battery wire. I just tried this with two different meters. I tried it with all the amp settings, including 10 amps. I don't get a reading even when I turn on the lights. I thought that in the 10 amp setting the lights would go on and I could read how many amps they were using.
When I put the cable back on the battery the lights go on.
What am I doing wrong?
DYohn
Moderator - Posts: 10,741
Posted: October 07, 2006 at 1:07 PM / IP Logged
Did you connect your meter leads to the "amps" positions on your meter?  They are generally different than the position for volts/ohms.
electrostatic
Copper - Posts: 154
Posted: October 07, 2006 at 1:14 PM / IP Logged
assuming you're using the correct sockets on the meter, you blew the meters fuses! what lights are you trying to measure and what wattage?
Prove your connections, use a meter!
I promise, I'll behave!
sprawl85
Copper - Posts: 204
Posted: October 08, 2006 at 9:38 PM / IP Logged
If it is over 10 amps you might as well get a clamp meter
They have a good variety at sears, I was lookin at them the other day.
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
Tuesday, October 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
