Have power, but no sound; Help
grayoldman
Posted: January 30, 2003 at 5:47 PM / IP Logged
I currently am experiencing a random issue of having no sound coming from a fully functional head unit when I start the car.  This occurs on either of two HU's, as I initially thought the HU was bad and purshaed a new one.  Once I completely disconnect the HU harness and reconnect, either will produce sound until some random time in the future, when I start the car and have no sound. I would like some direction in where to start tracking this down, for as you can tell I am a car audio novice and lost.  Car is an 89 Prelude SI.  Please help the old guy.
IT Lbs
Member - Posts: 8
Posted: January 31, 2003 at 1:33 PM / IP Logged
sounds like on of your speakers are shorted out. Take a meter and check all eight speaker connections and make sure you don't have any ground present when radio is off. Aslo check your power anti lead as well............Bailey
Platinum - Posts: 12,488
Posted: January 31, 2003 at 10:52 PM / IP Logged
Reloacte the ground wire, the ignition turn on wire & the constant wire to another source. Post your results.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
