Audiovox APS685 wont start
nowires
Member - Posts: 9
Posted: February 02, 2003 at 12:35 PM / IP Logged
I've installed an Audiovox APS 685 remote start in a Nissan Altima. Everything except it wont start. When you attempt to start the parking lights flash 4 times like it's starting but nothing
the12volt
Administrator - Posts: 3,959
Posted: February 02, 2003 at 1:22 PM / IP Logged
First check that you have the main leads from the remote start going to the respective leads in the ignition harness such as starter, ignition, ignition 2.
Also check that you do not have any of the inhibit leads preventing the unit from starting. Example: If you've connected a hood pin and are attempting to start it with the hood open, it will not start. Same applies with the brake lead.
I believe your unit may also have a separate toggle switch just for the remote start. Make sure you have this switch in the correct position and that it is wired correctly.
nowires
Member - Posts: 9
Posted: February 02, 2003 at 1:29 PM / IP Logged
Thanks for the reply. I've tried all of those, when I ground the hood pin and/or press the brake pedal the lights dont flash. When I probe the pins on the start connector there is 12v on both leads, when I try to start with remote, there is no reading on any of the other pins. Shouldn't Ign 1, ign 2 and the starter wire  go to 12v when the unit is trying to start the car? I  tried another unit and that didn't work either. I think I'm missing something simple.
the12volt
Posted: February 02, 2003 at 1:43 PM / IP Logged
Does your unit have multiple 12V+ power leads? If so, make sure you have 12V+ on each of those at the unit. Typically one is for the alarm and the other is for the remote start. Sounds like you do not have power on the one for the remote start.
nowires
Member - Posts: 9
Posted: February 04, 2003 at 7:37 AM / IP Logged
I have 12V on both power leads
nowires
Member - Posts: 9
Posted: February 05, 2003 at 12:10 PM / IP Logged
The unit is not sensing the tach input. The wiring diagram lists the GREEN/ orange wire in the pass kick panel as the source. There is no GREEN/ pink wire in the pass kick panel. Is there another source? also the unit doesn't seem to go into programming mode. Any advice?
my12volts
Member - Posts: 36
Posted: February 05, 2003 at 4:09 PM / IP Logged
the nissan altima has two starter wires !!!!!!!both must powerd` up....
my12volts
Member - Posts: 36
Posted: February 05, 2003 at 4:11 PM / IP Logged
CHECK YOU TACH WIRE AS WELL......IF YOU CANT FIND IT YOU CAN ALWAYS CET IT @ A FUEL INJECTER....
my12volts
Member - Posts: 36
Posted: February 05, 2003 at 4:12 PM / IP Logged
CHECK YOU TACH WIRE AS WELL......IF YOU CANT FIND IT YOU CAN ALWAYS GET IT @ A FUEL INJECTER....
nowires
Member - Posts: 9
Posted: February 05, 2003 at 4:38 PM / IP Logged
Thanks for the reply.  The unit won't start because it hasn't  received tthe initial tach signal. Now the unit won't go into program mode. I tried the procedure in the manual, just not working. Any suggestions? this one has been a real pain in ___!
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
