digital current meter
wireless
Member - Posts: 6
Posted: February 25, 2007 at 11:30 AM / IP Logged
i need to reduce 12v to 5v in my car. can i do this via a resistor, like done with an LED? or do i need to do something more complex? simple is better.
wireless
Member - Posts: 6
Posted: February 25, 2007 at 11:35 AM / IP Logged
sorry guys, please remove this on, a message kept telling me my post was not submitted.
fakepete
Copper - Posts: 99
Posted: February 25, 2007 at 11:43 AM / IP Logged
How much current does the meter require?
wireless
Member - Posts: 6
Posted: February 25, 2007 at 4:51 PM / IP Logged
the meter requires 5v to power up and will read up to 30amps.
KPierson
Platinum - Posts: 3,527
Posted: February 25, 2007 at 6:14 PM / IP Logged
Grab a 7805 5vdc voltage regulator from Radioshack.
Kevin Pierson
wireless
Member - Posts: 6
Posted: February 25, 2007 at 8:14 PM / IP Logged
how wold i go about putting that inline on the input side? 12v supply > 7805 5vdc voltage regulator  > meter?
KPierson
Posted: February 25, 2007 at 8:25 PM / IP Logged
There is an input pin (usually 7-30vdc), a ground, and a 5vdc output.
3 pins, and thats it!
Kevin Pierson
wireless
Member - Posts: 6
Posted: February 25, 2007 at 8:44 PM / IP Logged
ok, from all the diagram i've been looking at that regulator is usually accompanied by 2 small capacitors on a small pc board, so i didnt know if i could use it on its own or if i have to assemble a small circuit?
KPierson
Posted: February 25, 2007 at 9:02 PM / IP Logged
The caps will help with the regulation, but if you have a constant input voltage (such as a car battery) and your output isn't constantly changing you should be able to get by without them.
Kevin Pierson
jmelton86
Gold - Posts: 1,228
Posted: March 14, 2007 at 2:24 AM / IP Logged
wireless, where did you find this meter?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
