amplifier-speaker output...help
nbahoopstar
Member - Posts: 41
Posted: February 05, 2003 at 9:15 PM / IP Logged
The right rear speaker output on my amplifier (Blaupunkt around 1992') is not functioning. I have tested the right rear speaker wires to the left side(no problem) and sounds fine. I sometimes will get a very faint audio signal when I play with the wire when connected to the right rear output terminal, but that is all. Is this worth fixing and easily repairable? I have a digital meter and am familiar with it, if that helps. If not worth fixing myself, what 4x 75 would be recommended?
Loud Subwoofers only, do not make a quality car audio system, especially when they are worth more than your "car"
slobert
Member - Posts: 31
Posted: February 06, 2003 at 5:01 PM / IP Logged
have you tried switching the rca's?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
