electric gauge wiring
Zilverado
Copper - Posts: 92
Posted: November 04, 2007 at 9:02 AM / IP Logged
I am trying to intall an after-market oil pressure gause to replace the "idiot light" on my dash. The electric gauge I purchased has a sending unit with two signal wire pins, and came with two connectors. The gauge itself only has one signal "in" wire. If I hook up the gauge, I get two totally different reading from the different pins - neither seems totally correct. The instructions with the gauge are useless (only show one pin).
Should both pins be hooked up at the same time - and to the same signal "in" wire?
Any thoughts?
Zilverado,
Backyard Mechanic
1986 Chevy Truck & 1992 Nissan Pathfinder
Platinum - Posts: 13,725
Posted: November 09, 2007 at 4:45 AM / IP Logged
One lead from the sensor needs to go to the Gauge and the other lead needs to be grounded.
Zilverado
Copper - Posts: 92
Posted: November 09, 2007 at 3:18 PM / IP Logged
Thanks for the reply.
Grounding the second terminal is one thing I have not tried. I thought it just grounded through the actual sending unit-to-engine block threaded fitting. When I did a continuity test (prior to installation) between the threaded fitting and the terminals, both made the tester light up - so both terminals are at least somewhat grounded through the block (I don't know?), but maybe the resistance is different.
Either way, I'll connect the second terminal to a good ground and see waht happens.
Thanks again - Z.
Zilverado,
Backyard Mechanic
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
