login problems
raylo
Member - Posts: 38
Posted: May 30, 2009 at 9:42 PM / IP Logged
All of a sudden I can no longer login to 12volt forums from my laptop.  I get nothing, not a rejection or a message to try again, or wrong password.  It just says I am a guest.  I could login fine until a couple days ago.  I also read your notes on login problems and deleted all cookies.  No help....  So far I can still get in on my desktop which is good since I am in the middle of an install.  Do you have any suggestions re: access via my laptop.  Otherwise the laptop is working fine and has no issues with other forum sites. I've never seen anything like this before.
Thanks,
Ray
BTW, great site!
vibrationcustum
Copper - Posts: 171
Posted: May 30, 2009 at 10:01 PM / IP Logged
try deleting your cookies on the laptop, it states if you are having problems logging in to do this. If you did it then I don't know sorry
Can't be loud then don't have it.
(power acoustik system)
Head unit- TID-896 7" TOUCHSCREEN
ovn1-5500d 09 and another one coming soon
4-12" mofos 12ft3 box to 40hz (wall)
2 batterys, 1 power
Platinum - Posts: 13,725
Posted: May 30, 2009 at 10:14 PM / IP Logged
If you figure it out, let me know what you did. Until then you may want to try a new Web Browser. http://www.mozilla.com/en-US/
the12volt
Administrator - Posts: 3,959
Posted: June 01, 2009 at 9:37 AM / IP Logged
raylo, what browser are you using on your laptop? In addition to deleting cookies, try deleting your browser's cache.
login problems -- posted image. the12volt • Support the12volt.com
raylo
Member - Posts: 38
Posted: June 01, 2009 at 11:47 AM / IP Logged
Laptop is XP Pro, IE7.  Desktop is XP home, IE7, and works fine.  Laptop used to work fine on 12v.  I'll try the cache clear later.  Got to figure out a bypass issue with my new install first!
