port tube length
nafarious21
Posted: November 21, 2009 at 5:09 PM / IP Logged
I'm making my first ported sub box for a 15" MTX thunder 6000 4 Ohm and the box volume i'm gonig to be making is 3.5ft^3 and it calls for (2)4"x15" vent. Do they really make port tubes that long and if they do where can i get one that curves becuase the box is to small for 15" length.
whiterob
Copper - Posts: 351
Posted: November 23, 2009 at 10:54 PM / IP Logged
Yes, they do make port tubes that long. If you look on partsexpress.com you can find a port that has that length.
In order to be able to fit the port in your enclosure you should get a 90 degree bend. If you go to a local hardware shop such as Lowes you can find a 90 degree PVC fitting that will work. There are a few different sizes depending on the thickness of your port but you should be able to find one that will work.
nafarious21
Posted: November 24, 2009 at 5:52 PM / IP Logged
will the 90 affect sound performance and also if you are using a pvc elbow why cant you use the pipe as well?
whiterob
Copper - Posts: 351
Posted: November 24, 2009 at 6:14 PM / IP Logged
You can use a PVC pipe if you wanted. The 90 degree elbow will not effect sound quality.
I would look for something like this for an elbow for an example...
nafarious21
Posted: November 25, 2009 at 1:44 PM / IP Logged
alright thanks i learned something. oh and also the port tube calculator on this website says that the length should be (i cant remember exactly) 4" but the manual says 15" should i just stick with the manual?
nafarious21
Posted: December 17, 2009 at 12:49 AM / IP Logged
can anyone help me with this one?
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
