Posted: January 03, 2011 at 7:07 PM / IP Logged
Posted: April 02, 2011 at 9:57 PM / IP Logged
Posted: April 03, 2011 at 1:52 PM / IP Logged
Posted: April 03, 2011 at 3:09 PM / IP Logged
Posted: April 03, 2011 at 3:37 PM / IP Logged
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Then drill 2 holes in the brackets to secure them together.
Drill a third hole in the smaller bracket for the pivot point (the nail should fit tight in this hole).
Now simply put everything together like this.
My Dremel had a threaded hole for a set screw which is the square headed screw perpendicular to the threaded rod. Also the white plastic washer isn't necessary.
Just make it work with what you've got.
Feel free to ask questions if I didn't make something clear.
