fiberglassin door panels
trinisound
Posted: June 20, 2003 at 4:06 PM / IP Logged
I want to make some door pods (putting 6x9 on door) just need to make a riser[using MDF] and fiberglass, space is there just not depth in door
in the past when it was fiberglassed did not bond properly   and was easy to almost peel off any tips on how i can get a better bond with the fiberglass to the plastic
thanks
Mike
Platinum - Posts: 12,488
Posted: June 20, 2003 at 4:33 PM / IP Logged
Rough up the surface with a die grinder and 50 - 80 grit sanding disc. This will help the fiberglass to adhere to the plastic.
lncmarkviii
Member - Posts: 24
Posted: June 20, 2003 at 8:54 PM / IP Logged
you can also drill some hole by the edge of the panel for th efiber glass to adhear to
trinisound
Posted: June 20, 2003 at 9:19 PM / IP Logged
also forgot to ask should i use any particular hardener  and resin ?
Posted: June 21, 2003 at 9:20 AM / IP Logged
Usually the hardener that the fiberglass comes with is OK.
ezridr
Copper - Posts: 127
Posted: June 21, 2003 at 10:00 PM / IP Logged
You can aso use "West System" 2 part marine epoxy.
My mechanic told me, "I couldn't fix your brakes, so I made your horn louder"
T & A customs
Posted: August 08, 2003 at 5:21 PM / IP Logged
go to a body shop and ask about fusor's.  Fusor is expensive, but it will never crack.  i used it on my dash. and never had a problem
