Will it harden??
ciscored
Member - Posts: 8
Posted: July 08, 2004 at 8:25 PM / IP Logged
So I'm building an enclosure into my spare tire well. Today I soaked the material(using trunkliner) with Resin. I had about 1.5 quarts of resin left over from a previous project. I mixed this with about 1.5 oz of MEKP. The recommended mixture on the back of the resin said .5oz of MEKP per 1 qt. of resin. After soaking the material I went to clean up and found that I hadn't used the complete amount of MEKP Will it harden?? -- posted image. as there was still about .3 oz left in the measuring cup. My question is will it eventually harden?? Right now it's been about 3 hours since I finished applying the resin and it's still very soft and gooey. I don't care it takes all day I just want to know if it will get hard? Anyone know??
Thanks in advance....
auex
Platinum - Posts: 5,041
Posted: July 08, 2004 at 8:41 PM / IP Logged
Eventually it may harden. I would apply a relatively hot batch of reason to help it along.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: July 08, 2004 at 9:06 PM / IP Logged
Ambiant temperature and humidity can actually effect the curing time of resin as well.  So if it is a rainy day, it can take longer to harden for a given ratio.  If you added MEKP, it will eventually harden.
Steven Kephart
Adire Audio
defective
Silver - Posts: 642
Posted: July 08, 2004 at 9:40 PM / IP Logged
"ok... you need to put mekp in an empty windex bottle, then mask off..."   just kidding, actually, Steve's right. All you can do is wait, it will harden eventually, as long as there is SOME mekp in it. Actually, the less hardener you add the stronger it will be, it just takes longer to cure.
stormshadow
Member - Posts: 34
Posted: July 09, 2004 at 11:08 PM / IP Logged
I may get reemed for this. If you have a small radiant heater you could direct at the resin it may speed things up considerably.
Stormshadow.
Sobe_Death
Copper - Posts: 78
Posted: July 12, 2004 at 11:56 AM / IP Logged
i just pulled one of these. i mixed only about 14 drops of mekp with about 1/3 liter of resin. i think that it will be a while before it hardensWill it harden?? -- posted image.
