Problems with fiberglass enclosure
Gbelous
Member - Posts: 30
Posted: January 31, 2005 at 11:51 AM / IP Logged
My brother and I worked on a fiberclass enclosure for my car.  It is coming out pretty decent considering it's our first time with fiberglass.  It is to the point where I have a few layers of fiberglass on it and a couple coats of Bondo.  I know it still needs more bondo and then sanded and painted, but the issue now is that it doesn't sound too great.  I calculated the correct port, but the entire box itself just vibrates a lot.  If I hold it down with my hand the bass sounds much cleaner and deeper.
How can I make it more solid so it doesn't vibrate as much?
I was thinking a few things...add more fiberglass to the inside, add more bondo to the outside, layer sound absorbant material on the inside (Sound-Off) or a combination of everything.  Any ideas?
Or could I put some better supports on the inside and secure them to the box?
Problems with fiberglass enclosure -- posted image.
realitycheck
Silver - Posts: 751
Posted: January 31, 2005 at 12:24 PM / IP Logged
You're probably going to have to add more layers to it, I know the bondo is not going to stop the vibration.  If you can add more layers to the inside that would be easier on you but its going to be really hard to glass on the inside of the box.  If you sanded all the bondo off and then added more glass it will be easier for you in my opinion. If there are any flat parts you can cut out pieces of mdf to match the flat area and glass it to the inside of the box.   How many layers did you put on there???
oonikfraleyoo
Gold - Posts: 1,069
Posted: January 31, 2005 at 8:03 PM / IP Logged
Not to disrepsect your math skills but unless your a calculus major a ported fiberglass box is extreamly hard to design even if it is thick enough.
branvw
Copper - Posts: 90
Posted: February 03, 2005 at 4:43 PM / IP Logged
i agree with oonikfraleyoo, it is almost impossible, I have tried it many times, now i have givin up, i will only do sealed!
Alpine Guy
Platinum - Posts: 2,478
Posted: February 03, 2005 at 7:58 PM / IP Logged
Iv managed to do it, but its a pain in the arse, ,the box has to be big, and you have to be able to accuratley measure it with packing peanuts or sand.  Then make a slot port, cut a hole in the enclosure, slide it in, then fiberglass it in there.
