multiple window modules?
thsonnen
Member - Posts: 27
Posted: March 04, 2005 at 6:39 PM / IP Logged
Getting ready to install an Autopage 855lcd into a custom
1991 Caprice. Going to install 2 DEI 530T's to roll all 4 windows up and down. The car also has a motorized rag top sunroof, and I have two AU-93's laying around, that I would like to install onto the sunroof. The instructions on the AU-93 tells you not to hook up the 500ma activation wire to anything but the orange wire, and to use the pink wire for any other device. If that's
the case, would I use the pink wire to diode isolate the 530T's and the 508D perimeter sensor, and the starter kill, or should I come off the 855's orange wire instead
and diode isolate all the sensors from there? Also, what diode should I use, the IN4006 or IN4002. Any help is greatly appreciated.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 04, 2005 at 7:33 PM / IP Logged
Might wanna try posting this in the security forum.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
