Posted: September 04, 2005 at 1:39 PM / IP Logged
Posted: September 05, 2005 at 8:41 AM / IP Logged
Posted: September 06, 2005 at 9:29 PM / IP Logged
Posted: September 07, 2005 at 4:19 PM / IP Logged
Posted: September 07, 2005 at 8:33 PM / IP Logged
Posted: September 08, 2005 at 9:32 AM / IP Logged
Posted: September 08, 2005 at 9:41 PM / IP Logged
Friday, May 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I am in the final stages of my install and need to mount a 6" woofer where the door map pocket is. I tried to make a "new" pocket out of wood, but alas, its contoured and very difficult to match (and I stink at fiberglass so I'm not going there). So my Plan B is to take a couple of these map pockets and piece them together in order to make a "solid" front. Then I'll bondo the cracks and cover with carpet (as the oem ones are). What I need to do then is to fill the inside of it with something that I can cut and drill into to mount the 6" woofer. My guess is at least a 1/2-3/4 pint of whatever is going to be needed per door pocket to make the area solid.
I thought of Bondo but understood when its that thick it cracks easily. Any ideas?
Thanks in advance.
) has taken me the better part of 2 weeks. No idea how some of you guys do this for a living....but I'm glad you do :)
