Posted: April 21, 2006 at 12:20 AM / IP Logged
Posted: April 21, 2006 at 7:07 AM / IP Logged
Posted: April 21, 2006 at 8:37 PM / IP Logged
Posted: April 21, 2006 at 10:46 PM / IP Logged
Saturday, April 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I plan on taping the metal and making the shell along the trunk edge and using a MDF board for the front in which I'll mount the two 10" subs.
FYI, the car is a 2003 Chrysler Sebring GTC and these are RE-10 subs. The website specifies that each sub should have .83ft^3, but when I talked to one of the techs from RE they said I actually only need .5ft^3 to get the tightest bass, but the official spec will give me lower tones. He also said that the cone/magnet has a displacement of 1ft^3. My plan is to make the shell and turn it on its side and fill it with the desired volume of water then mark where the surface touches along the fg. I can then cut along the mark and mound the MDF there for a fairly exact volume.
Also, I purchased the following materials from SelectProducts.com:
1qt MEKP hardener
1gal Fiberglass Resin
Stitched Mat 12OZ 50"" x 2YD"
