wiring leds
desitdt
Member - Posts: 15
Posted: June 11, 2009 at 5:06 PM / IP Logged
what is the best way the wire 7 led's for underdash lighting? i have plenty of resistors but the leads on the leds dont reach very far.
bigjohnny
Copper - Posts: 293
Posted: June 12, 2009 at 8:53 PM / IP Logged
I usually cut the positive lead on the led really short, and one leads of the resistor really short, and solder it right to the bulb then seal it up with some heatshrink. you will still be left with lots of lead, I just like having the resistor as close to the bulb as possible, when possible.
otherwise you can search for LED wiring calculator, there are tons out there, they will show you various ways to wire LEDs and what resistors to use for a certain voltage.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
