looking for 194 leds
derrickg
Copper - Posts: 119
Posted: June 21, 2009 at 10:35 PM / IP Logged
i have tried superbright leds they work good for 6 months and burn out .who makes long lasting leds in oem sizes.
Platinum - Posts: 13,726
Posted: June 21, 2009 at 10:40 PM / IP Logged
Define OEM size. Did you limit the current properly to the ones that lasted 6 months?
kevinluo0406
Posted: January 15, 2010 at 10:04 AM / IP Logged
looking for 194 leds -- posted image.
194 5LEDs auto bulbs as above,the bulbs can get 30k hours,please kindly note,
liquidaudio_ss
Member - Posts: 21
Posted: February 16, 2010 at 10:32 AM / IP Logged
i agree with kevinluo0406, i do tons of led conversions and they should never burn out always try to use SMD led's like in the picture they are the best quality by far
Liquid Audio Styling & Sound Ltd.
Red Deer, AB, Canada
403-352-2224
dereileak
Copper - Posts: 113
Posted: February 24, 2010 at 7:21 PM / IP Logged
sounds like your sending to much voltage to the led's, try adding in resitors, you need to calculate your led voltage and what your battery is sending out, remember when your driving it sends out more then 12.5 volts, more like 13.5 or even up to 14.5, which my van does sometimes when charging, you can buy a 12 volt voltage regulator, its like a 50 cent piece that sends any extra current to ground I believe, but requires 12.5 or higher to run, its on partsexpress.com
Viper 5902 - Ordered
Kicker Dual CVX 15's - Installed
Kicker ZX 1500.1 Amp - Installed
dereileak
Copper - Posts: 113
Posted: February 24, 2010 at 7:26 PM / IP Logged
here is a link to that part LINK
oldspark
Gold - Posts: 4,913
Posted: February 25, 2010 at 1:31 AM / IP Logged
A voltage reg is a bit overkill.
Note too its spec of Vin: +14.8 V min - they typically specify a 3V drop across them. Use a zenor-resistor or current limiter etc instead - much cheaper!
