prelude led front daylights
telerepairman
Posted: October 20, 2009 at 2:24 PM / IP Logged
Fitted led lights to Honda Prelude (`97) European spec. Is there anywhere in the engine bay where I can connect these low voltage lights to. Don`t want to use sidelights (parking lights?) connection.
t&t tech
Platinum - Posts: 2,622
Posted: October 20, 2009 at 4:24 PM / IP Logged
Well if you want control independently, it would be wise to connect the turn on device inside the car where it is easily accesible, you can do it in the engine bay, only drawback is you would have to pop the hood to turn the leds on! prelude led front daylights -- posted image.
telerepairman
Posted: October 21, 2009 at 11:04 AM / IP Logged
Doh ..I should`ve said- I simply want the lights on when ignition on .Don`t require independent control.
Hoped a honda head could say : As you`ve no 4  wheel steer or air con you could tap off the.....circuit at the under bonnet fuse box or even:
tap into horn/washer motor/ or other loom in engine bay.?
Seems crazy to run wires back and fro through bulkhead when there must be spares both sides.!?
t&t tech
Posted: October 21, 2009 at 10:42 PM / IP Logged
An ignition feed can be easily found at the fusebox under the hood, or the harness that enters through the firewall!
telerepairman
Posted: October 22, 2009 at 8:05 AM / IP Logged
Fusebox already located but how to connect to it?
Can`t I use any of the terminals already there in fusebox ? Must I disconnect the fusebox from the chassis to access the wires?
What type of connection are you assuming I`m making?
There has to be an easy way!!
t&t tech
Posted: October 22, 2009 at 3:55 PM / IP Logged
The wires that exit the bottom of the fusebox, I am sure they enter a factory wiring loom that leads to the cabin of the car, can you trace this and possibly find a part of the harness where your hands can work to open the harness up and test for an ignition feed, i'm positive you can!
You will also need a meter or a test light!
P.S- would have saved you a heck of alot of time and energy to just run a single ignition feed wire into the car and connect it to the BLACK / YELLOW at the igniton harness!
telerepairman
Posted: October 30, 2009 at 6:02 AM / IP Logged
Hi , Thanks Decided to run an untidy wire from battery via fuse to front lights with a switch.Shall add remote control to a relay later.It`s messy but it works.
