courtesy lights
micrors4racer
Copper - Posts: 88
Posted: April 08, 2010 at 12:00 PM / IP Logged
I am trying to put in footwell lights in a 1985 Toyota Corolla GT-S. Some how I can't find a +12v when the doors are open. Where can I find the +12v that turns on the dome light? The doors are negative trigger so it is 0 when the doors are open.
91stt
Silver - Posts: 564
Posted: April 08, 2010 at 3:37 PM / IP Logged
Depending on how much current the lightbar pulls, it may be better to +12V from the fuse box or better yet run a dedicated fused wire from the battery
Than you can use the door trigger for your switched ground
micrors4racer
Copper - Posts: 88
Posted: April 08, 2010 at 11:30 PM / IP Logged
So hook up a relay and use the ground as the switch?
oldspark
Gold - Posts: 4,913
Posted: April 09, 2010 at 4:53 AM / IP Logged
If it's low power (under a few Amps) and it is a normal earthing switch (with no sensing or other circuitry between your added lights & the switch), you should not need a relay.
micrors4racer
Copper - Posts: 88
Posted: April 09, 2010 at 2:22 PM / IP Logged
So postive from the leds to a constant 12v then the ground into the door switch? Wouldn't it short once I close the doors because it will apply both 12v from the positive then 12v from the door switch?
oldspark
Gold - Posts: 4,913
Posted: April 09, 2010 at 3:25 PM / IP Logged
What short? That's 12V to 12V.
And it's not a short - the LEDs are in between.
micrors4racer
Copper - Posts: 88
Posted: April 09, 2010 at 5:32 PM / IP Logged
Oh yea, wasn't thinking. I got them wired up now like that thanks!
oldspark
Gold - Posts: 4,913
Posted: April 10, 2010 at 12:53 AM / IP Logged
courtesy lights -- posted image. You weren't thinking? At least you have an understandable excuse.
I do think and I still make similar silly's!
What's worse is that I've worked for telco's that typically use +ve ground for traditional equipment so you'd think I'd be used to "inverted" drawing switching.
Yet I still have to think carefully about your situation. (Even though I have oft decribed the benefits of ground switching as used in most digital logic etc - aka Open Collector outputs.)
But these simple things are like a genius tying shoelaces - too trival to learn, or in out case, to waste our genii on.
Cheers.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
