led's on door lock and unlock
98greenranger
Posted: June 20, 2010 at 1:13 AM / IP Logged
I am needing help on how to wire a dual led( RED / green) to come on and stay on when the doors are locked or unlocked. I would like to have unlocked be solid green and locked will flash red. I want to put power door locks on a originally manual setup( I do not have the kit yet)
I was thinking of using a flashing relay for the red side, and a regular relay for the green side, but Im starting to get confused when I try to figure in the lock and unlock side of it. I am thinking it is just a momentary signal for both lock and unlock. How can I wire this up to where the unlock/lock momentary signal to turn into a constant 12v?
I am no good at saudering/circuits etc, can this be done with relays only?
Thanks!
98greenranger
Posted: June 20, 2010 at 1:18 AM / IP Logged
Also could someone recommend what door lock kit I need to look for( number of wires etc) for this setup?
Platinum - Posts: 13,725
Posted: June 20, 2010 at 5:13 AM / IP Logged
You will need to get a magnetic switch like the ones in the following ink, IT MUST BE a SPDT  (Single Pole double Throw) configuration.  You may have to go to a home alarm company to get one.
http://www.jayso.com/shop/category.aspx?id=124
You will have to mount the switch to the door, and attach the magnet to the moving part of the door lock mechanism.   Radio Shack sells a 12 volt flashing red LED.  THey may also have a 12 volt green one.  If they do not have a 12 volt green one, they will have a green LED and a 1K 1/4 watt resistor.
Let us know when you get the above items and I can draw you a diagram.
flobee4
Silver - Posts: 585
Posted: June 20, 2010 at 8:59 AM / IP Logged
Radio Shack also has Bi-color LED's so you don't need to have to mount a single red and a single green LED. You mount 1 LED and it changes color based on the polarity of the input.
Bi-Color LED
They also have a Tri-Color LED with a common Anode(negative) and 3 other legs of the LED turn on either the blue, green, or Red color based on where you place the signal.
Tri-Color LED
98greenranger
Posted: June 20, 2010 at 9:35 AM / IP Logged
Thanks for the replies! I think I have a different idea than using the magnetic switches. I found these on the site:
https://www.the12volt.com/relays/relaydiagram21.html
and this one
https://www.the12volt.com/relays/relaydiagram52.html
Once I get the kit, I can figure out which one I need to use. For the flashing red led I can use a flashing relay inbetween the 12v output and the led. There is another pic of a mechanical latching relay on the site but no idea where to get it.
led's on door lock and unlock -- posted image.
It is also on this page here:
https://www.the12volt.com/doorlocks/page4.asp#sppbdl
I think that would be the cleanest setup. If im reading that right the 1st output could be red led and the second output could be green or vice versa. Probably 87a for the green led.
Posted: June 20, 2010 at 9:45 AM / IP Logged
I did not look at the second diagram you posted, but with the first one, if you do not drive the car every day, expect a dead battery.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
