my headlight wig wag design
drifter58
Posted: July 23, 2010 at 10:01 AM / IP Logged
my headlight wig wag design -- posted image.
this is my newly designed wig wag system, I'm not a 100% positive if it will work correctly yet but i figured i would post it up to see if you guys saw anything wrong with it, something i missed maybe
basically i used four relays for the purpose of back feed electricity, it basically mean's i can install this onto any car whether or not the head lights are run in a parallel. and i also used a 3 prong flasher relay.
hope you guys like it.
oldspark
Gold - Posts: 4,913
Posted: July 26, 2010 at 5:06 AM / IP Logged
Firstly I am NOT used to looking at physical representations - I much prefer circuit schematics - ie, showing functional switching and paths.
Secondly - I assume the flasher can is suited to drive a mere relay coil?
Thirdly - as I read it, the lower right relay does nothing other than connect battery+ to H (ie - the power output from the headlight switch or relay) in both positions.
And also the upper right relay shorts battery+ through the switch to GND.
FYI - convention is that the more +ve is 86 with GND etc being 85, though this is only important for relays with inbuilt spike suppression diodes (which I never use - I use plain relays with my own external suppression diodes).
Maybe if you explain what you are trying to do is a good starting point.
The available hardware also worth describing (555 or other timing circuits; whether highbeams are relay powered, etc).
cruzinlow
Posted: July 31, 2010 at 5:24 AM / IP Logged
Kind of reinventing the wheel here because of all of the headlight wig-wag flashers on the market, and ones that can even have different patterns, and totally solid state so no noise. For total isolation, you can use one designed for Chrysler/Dodge vehicles. Can still be a fun project if you have the time to experiment. Depending on the 3-prong flasher you use, the relay coils may not draw enough current to alternate properly.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
