remote controlling lights
fleetboy
Posted: September 22, 2010 at 12:00 AM / IP Logged
I have an exterior light kit that for now is controlled by a toggle switch. I want to add a remote control and keep the toggle switch.
 Is there a relay module(model name and number) that allows for remote and toggle switch control for the same circuit? I'm thinking if I wire up the remote controlled relay into my existing circuit the remote control module wouldn't like it when I use the toggle switch.
I'm trying to not use a diode out of preference for now.
oldspark
Gold - Posts: 4,913
Posted: September 22, 2010 at 6:03 AM / IP Logged
Like a SPDT relay? The remote energises the relay whose #30 goes to lights; #87 to fused +12V; #87a to the toggle switch output (+12V).
There will be short a break when the relay switches over.
fleetboy
Posted: September 22, 2010 at 10:51 PM / IP Logged
That sounds like what I need. Where can I find a SPDT relay that uses a remote? Do you have manufacturer name and model number?
oldspark
Gold - Posts: 4,913
Posted: September 23, 2010 at 2:46 AM / IP Logged
You find a remote control that does what you want.
Remotes might use relays, but relays don't use remotes.
All you need is a remote that turns something on and off. (The relay may be built in.)
Try a search for remote control 12V relay changeover... etc.
If it is simply on-off (not changeover), then use that to switch a change-over relay as I described above.
fleetboy
Posted: December 30, 2010 at 6:44 PM / IP Logged
where can I get the parts that i need.
12vlost
Member - Posts: 44
Posted: January 03, 2011 at 3:51 PM / IP Logged
Any generic wireless receiver/transmitter will work,Ebays full of them from $10 up!
They come in toggle/mom/latched flavours,just connect an spdt relay to suit!
oldspark
Gold - Posts: 4,913
Posted: January 03, 2011 at 5:58 PM / IP Logged
12vlost - Where were you for wireless control of horns tx/rx...??!!!
And don't tell me you were temporarily lost! remote controlling lights -- posted image. remote controlling lights -- posted image.
(Yes, I may be venting a bit remote controlling lights -- posted image. - but NOT at this thread nor you nor fleetboy!)
And thanks.... with apologies to fleetboy - I didn't respond to your last reply.   remote controlling lights -- posted image.
12vlost
Member - Posts: 44
Posted: January 03, 2011 at 6:25 PM / IP Logged
Never been on here for a couple of years,I was lost but now like you,I know everything ;-)
oldspark
Gold - Posts: 4,913
Posted: January 06, 2011 at 4:29 AM / IP Logged
fleetboy - see mp3car's Remote control momentary "switch" on EBAY - some nice remotes for ~$10 (2 button) & $14 (4 button, water resistant).
12vlost - glad I found you. Better late is better then never - but you know that.
12vlost
Member - Posts: 44
Posted: January 09, 2011 at 3:24 PM / IP Logged
Possibilities are endless,only limited by our imagination my friend remote controlling lights -- posted image.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
