trying to fix led headlight
sks66
Posted: November 26, 2010 at 12:02 PM / IP Logged
Hello. Can anyone tell me how to convert 8pin to a 6 pin adapter. (Sonata Headlight)
I got the adapters that i will convert but the problem is wiring.
In one adapter i have 8 wires : Red,black, white, braun, green, yellow and 2 times blue.
The second adapter has 6 wires: Red, black, white,braun, blue, orange.
These adapters are for a Hyundai Sonata 2009 headlight. Originaly i had 8 pin headlight but i ordered a aftermarket headlight with leds and this one has 6 pin plug so the dealers who sent me headlight has included a adapter to convert from 8 pin to 6pin but they could not tell me the wiring process because of the policy thing. I will be using Highbeam, lowbeam, parkinglights, turnlights. i believe for the fog light it has different wiring.
So if anyone could tell me how to fix it i would appreciate it.
Thanks..
sks66
Posted: November 28, 2010 at 5:36 PM / IP Logged
No one knows????
Do someone have the headlight switch diagram for the Hyundai Sonata 2009 .??
heinstal
Member - Posts: 34
Posted: December 01, 2010 at 4:12 PM / IP Logged
all i can tell ya is start testing one by one......chances are black is ground and it should be connected to each of the light sockets, and then add 12 V to your aftermarket lights, see which wire lights up which light, and then with a multimeter (or line tester) see which wires from the car side do what.....good luck
~~~wael~~~
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
