wiring a led strip to ac adapter
45acp
Posted: June 26, 2012 at 9:22 AM / IP Logged
Is is ok to wire a 12 volt led strip to an ac adapter? I am going to be mounting this on my bullet reloading press. I have several ac adapters laying around but not sure if its safe.
http://www.harborfreight.com/9-inch-led-blue-strip-lamp-98409.html
That is the strip I am planning on buying.
Is it safe/ok to do this?
Thanks!
Kev
KPierson
Platinum - Posts: 3,527
Posted: June 27, 2012 at 9:41 AM / IP Logged
If the AC adapter adapts the AC to 12vdc then it should be fine, assuming the AC adapter can safely provide the current that the LED strip needs.
Kevin Pierson
