move drl from headlight to fog
sse1990
Posted: October 12, 2013 at 12:35 PM / IP Logged
I've got a 2012 GMC sierra that uses the low beams as DRL. There is a signal wire from the BCM (LT GREEN/ blk) that runs to the DRL PCB Relay, that is connected to the lows. My fogs have a signal wire from the BCM (DK GRN/WHT) to the fog relay.
What's the best way to move the signal wire from the DRL relay to the fog relay and still maintain the factory fog signal wire.
I was thinking of adding diodes to prevent the BCM DRL signal from going back into the BCM fog signal and vice versa, but is it needed since they are negative BCM signals?
I've seen other ways by adding a relay after the DRL relay and converting the output of the second relay to negative to trigger the fog relay, but that starts to look crappy when you open the fuse box.
powerslave
Copper - Posts: 126
Posted: October 18, 2013 at 12:49 PM / IP Logged
I know you said using a relay it looks CRAPPY in the fuse box, but that is the way to do it.. Actually, it's just one jumper wire to the FOG relay in all actuality.
You only need to run a jumper from the coil input side of the DRL relay, to the coil input side of the FOG relay, with a DIODE in the jumper.
DRL ---->|---- FOG
powerslave
Copper - Posts: 126
Posted: October 18, 2013 at 12:50 PM / IP Logged
Can't edit my post, so:
The DIODE will prevent current going back to the DRL relay when the FOG lamps are on manually; thus it won't trigger the DRL relay too.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
